Please please please help all you Smart people out there! I drove a long way to see a 84bhp that's for sale, everything appeared to be perfect until I took a look underneath the car. I saw what I saw shown in the picture and the guy had no knowledge about it. Apparently, the car had a service only last month and what could it be? He said he's going to sort it out before we proceed any further. Should I stay away? Your invaluable comments and advice will be greatly appreciated. Cheers a lot!
Wet patch underneath the engine...
Given where it is, it is really hard to say with any certainty as to what it may be. It doesn't look fresh though. If it is oily to the touch, it might be runoff if the person doing the service spilt some oil past the oil cap but I can't be sure. As far as I know, the 84bhp doesn't suffer with oil leaks particularly.
- 1 like
Originally posted by Wesley Smart View Post
I wanted the car to be inspected properly by a specialist garage but unfortunately the seller had declined my request so I gave the car a miss!!
If it is the rear crank seal leaking it is only a matter of time before the clutch becomes contaminated and begins slipping (if it isn't already) and creates another expensive problem.
Good luck with the search - and apply the same level of discernment you have with this car!
- 1 like
Indeed, good call. If you are not sure, always walk away, there are plenty out there
...and now I am looking for a Brabus..........
http://www.ebay.co.uk/itm/Smart-fort...-/321989878685
http://www.ebay.co.uk/itm/2011-SMART...-/222453592652
- 1 like
The GB-10 is a trim level which is not specific to an engine. The engines only changed the once around the end of 2008 for the MHD (from a petrol point of view). In short, the way to tell if a car is a MHD is if the switch by the gearstick is present (to turn the stop/start off) and the car has the "Eco" lights in the instrument cluster, though I am not sure if they are also present on the turbo 451s and the diesel varieties as well and are just never used along with the badge on the boot.Last edited by Ocracoke; 15-04-17, 10:15 PM.
