Wiring Help
  • Wiring Help
    Hello.
    I purchased my 2002 smart pulse a year ago and it already had a panisonic head unit fitted in it. This was fine, however when I switched the ignition off, the next time I got into the car the head unit had reset and the stored stations had gone and it was back to factory settings.
    After a year I'm starting to get a bit annoyed with it and am looking at getting it fixed.
    I have looked at the wiring and it would appear that some of the wires from the head unit don't match up to the car wiring. I have looked at this and identified the power wires apart from the speaker wires, but I still can't work it out.
    So the car wires are like this
    1 - brown
    2 - pink/blue
    3 - brown/white
    4 - empty
    5 - blue
    6 - empty
    And from my head unit they are patched like this...
    2 - black - which connects to brown (1) car wire
    1 - red (acc) - which connects to pink/blue (2)car wire
    3 - blue/white (remote) - which connects to a blank connector on the car loom
    4 - blank
    5 - blank
    6 - yellow (battery) - which connects to Blue (5) car wire
    I'm just not sure which wire from the head unit should be meeting which wire in the car loom?
    Any ideas? Thanks
    You need to switch 2 wires of the radio -yellow to red, red to yellow.
    Take a look on evilution.co.uk.
