Finally!
I have completed my new mod on my new brabus exhaust now only done 9 miles: D
I must start by saying, I tried doing this myself for the 1st 20 min and gave up as my back was murder (i have a bad back) So my dad took over, and about 1.5 hours later all done!
Ok. . . So to do this you need:
Electric Drill
Circular drill part (not sure what size, just so it fits in the pipes)
A towel to kneel on
So my weapon of choice:
What the exhaust looked like before, ridiculous how they have blocked this exhaust up:
You need to be careful when putting the drill part inside not to scratch your lovely exhaust, once in start drilling!
It took about 10-15 min to get the plate out!
Take your time, as if you are too quick, you will go through and drill into the mesh behind the plate we are taking out. Which is bad i guess.
Take your time . . . be steady and it cut nicely.
Once it has cut it will not fall out, keep checking your progress every minute or 2.
Once cut as much as you can, wiggle the plate with some pliers for a few minutes and it will break free.
THEN - it will look like this
I took the car for a spin afterwards, straight away when firing it up, it’s allot deeper, sounds grunty.
When driving, it does not drone. When you floor it, it’s not too deep, it’s the same as it was just louder, and sounds like it’s got a real nice grunt. However, my exhaust has only done 9 miles so will take a few hundred miles for it to take proper affect.
Power wise, im allmost cetain it felt quicker and more responsive, but like I said exhaust has only done 9 miles so I will keep you all posted.
Hope this helps!
Electric Drill
A towel to kneel on
Hope this helps!
