Can anyone recommend my some new discs & pads for my 450
  • Can anyone recommend my some new discs & pads for my 450
    Hi Guys,
    Going to be attempting my first ever change of the discs and pads on my 450.....never done it before so hopefully it goes ok.
    I was hoping someone might be able to recommend some discs and pads for me. I'm on a tight(ish) budget at the moment so I really need something that is relatively well priced but of good quality.
    Thanks.
    Eurocarparts.com - their front page has an offer code on, currently 25% off brakes. Pagid is meant to be a good brand, and you probably can't go far wrong with Bosch either.
    Try the code MAY31 - might get even more discount!
      Smart/MB prices are frequently better than you might expect. Ask for a discount as well (which I think they give to loyal customers). Worth a phone call if there's one close by.
      Other than that, as per J500ANT's post - recognised brand from one of the discount outfits.
        I got some from eurocarparts disks and pads by eicher, having had them about 2 months they are very good IMO and I think better than the standard items I had. Disks were £34 and pads were £13. If you go for them I have a spare disk if your interested.
          Pagid are very good.
            Depends on how you drive your vehicle. If your not a spirited driver then something from Eurocarparts will be fine, if your foot tends to be on the heavy side try something for a more performancec orientated brand. I purchased some pagid's for my run-around from eurocarparts and they seem fine
            Edit: Grab some copper grease if you haven't already, squeaky brakes are annoying!
              Remember that you will also need an E18 Torx socket to remove the calipers.
