lambda sensor
  • lambda sensor
    does anyone know the part number of a pre cat lambda sensor? 4 pin for a 2016 forfour rwd petrol 900cc tried eBay, none fit. smart won't give me part number. thank you
    You should be able to enter your reg # into the likes of Eurocarparts and get a match.
    Pretty sure one 4 wire sensor is like another 4 wire sensor - generic. What I've heard is avoid the cheapest ones as they don't ;last long. IIRC Bosch ones are worth tracking down.
      ok, thank you. i did put my reg number on eBay and said it would work also but I'll try that thanks
        Here you go >> https://www.google.com/search?q=lamb...w=1366&bih=625
        Bound to be something there. If any uncertainty, ask vendor what their return policy is.
          Another thing, you didn't state fuel type.
          Did you check via key word search on Evilution?
          All the listed part number options are there on a scroll down list.
          Ebay proves very fallible their vehicle search engine suitability sucks tail pipe gases.
            Simple to find one on Google, just type in search for "Lambda sensor Smart 453".
