hi, Just joined the Smart community and already needing help.
Bought add on pods for my fortwo. As usual no instructions and though must be simple. Took off dash top and found nothing to connect rev counter. I did find the connection for the clock on the side of the circuit board. I take it you use the black connector and then push in the one on the ribbon cable. Got the light to work so I think that's sorted. I was told that the connection for the RPM was there as well.
Well it obviously is not , length of cable a bit of a give away, anyway where is the connection and how do you get at it?
Not so smart (owner)after all :frown:
