this is my own personal review of the EXP throttle body fitted to my smart 450.
First of all it cost me about £50 off ebay then £14 for the spacer and gasket of SmartMods http://smartmods.co.uk/index.php?page=details&id=78 so i cant complain about the cost of this mod at all.
Fitting instructions for the throttle body can be found here http://www.evilution.co.uk/773
I personally found fitting my Mocal inter cooler pipe over the larger EXP throttle body a nightmare, there is such a large size difference over the standard item it has to stretch ALOT, but dont let this put you off keep at it and eventually it will go on (a second pair of hands might help).
Its also worth noting that you should place the 4 torx bolts through the holes on the throttle body BEFORE you fit the inter cooler pipe as once the pipe is on the thickness of it fouls the holes slightly, i found this out the hard way by putting the pipe on then realising the bolts wouldn’t go in as the pipe was blocking them.( it had to come back off **cry's in corner**)
once it was fitted i left the battery off for 10mins so the car could learn from scratch as it now has the potential for a lot more air flow (not sure if this is correct but its what i am led to believe)
When i drove the car for the first time with this beast in place i was gob smacked, i was hoping it would make a little bit of difference but it made one hell of a difference, so much more responsive and seems to have made my car a good amount faster.
im not sure if it will be the same kind of gains on everyone’s car as mine has roadster turbo free flowing exhaust ect ect but its well worth the money and effort in my opinion.
My car is now running 0-60 in 10.5 seconds before this mod it was 11.35 thats a good diffrence in my books.
