Hi, SmartManiacs!
I am a newbie. I am sure there are already posts about ESP but i can't find them - coz I is stoopid!
I have a Smart 450 ForTwo Brabus 698cc turbo petrol 2003.
The Yellow ESP/ABS warning triangle flashes a lot when there is no obvious resaon for it to do so.
After it has flashed a few times - sometimes a dozen or so, the light stays on solid and acceleration is prevented. The car is brought to a halt. Stopping and starting the engine resets the ESP and the car drives for a bit longer before doing the whole thing again. Sometimes it will go for days without playing up. There is no obvious weather or road condition factor. All conditions seem fair game. Perhaps the only time this behaviour is reduced is when driving very slowly for short distances - paper shop, etc. The faster one drives the more likely it seems to happen. Bumpy roads may make it worse but not always. Of course we may be seeing a combination of "real" and "fake" ESP/ABS activations, just to confuse things.
I have checked the following:
1) ESP Control unit: no water ingress or corrosion, properly mounted and connected.
2) Reluctor rings: all sound and bright.
3) Wheel sensors: correclty aligned, tight and clean.
4) G-Force sensor: correctly mounted and connected.
5) Brakes: No leaks or much wear, fluid level ok and reservoir level sensor working.
6) Handbrake and warning light system ok.
7) Yaw sensor firmly mounted and connected.
8) "Trust" Plug utilised but light still stays on and engine still cuts out! (This is very strange, indeed!)
9) Star machine detects NO FAULT CODES
Yesterday, my wife was on the M4 in traffic, with roadworks and no hard shoulder. The orange light stayed on twice within a few minutes and brought the car to a halt - a very hairy experience. I consider the car now too dangerous to drive and the local Mercedes garage cannot find the fault.
Has anyone else had this or a similar problem? Have I missed something? I can have the ESP controller checked for about £55 and buy a new one for about £500 but if I do this as a last resort and it doesn't fix the problem, I shall have to disable the ESP system to be able to drive the car, which is inadvisable for very long.
Surely faulty sensors or controller should throw up some Star diagnostic scan codes?
HELP PLEASE!
Keith
HELP PLEASE!
Keith
