Hi guys, I've just noticed the intercooler fan on my Mk5 never runs?
I'm sure it used to & in this weather I'd have thought it would of run after shutting the engine down, due to heat soak.
Also there is a noticeable smell of petrol, as if the engine is running rich all the time.
I've had a look on Evilution.co.uk & Kane suggests the IAT sensor could be at fault.
Well I've taken the sensor out & given it a clean. I also put a meter across it & got a reading of 3.8KΩ, is this correct? Not sure what type of sensor it is, so not sure of it's o/p.
Martin.
Martin.
