Greetings All, here's a new one, I've searched this site already and nothing like what I have. The problem is the ABS light. Turning the ignition on, should see the light illuminate and then extinguish. In this car, the ABS light does not illuminate at all. The instrument cluster has been removed and the bulb is fine, swapped a couple of bulbs about and in other positions they're fine, just not in the ABS position - so nothing wrong with the bulb. Questions are, where does the voltage come from to turn the light on and what enables the light to turn off. Thoughts are, that, a) the voltage is not getting to the light to turn it on. Or b) whatever enables it to turn off, has it turned off all the time, so it won't turn on to begin with.
Had the car connected to a Star machine and there's a 'logged' fault with the ESP but not (F) or (f), just a (!) - what's that mean??
Currently the battery is disconnected it will remain that way for about 12 hours, I'm not holding my breath on that one, for being the fix.
Brake lights and gear changes happen as the should, it drives fine, accelerates fine and stops fine. I've not stomped on the brakes though to see if the ABS actually works.
Yes, this is a most different fault, normally the ABS light stays on.
Has anybody got any thoughts, before I pull the car to bits???
Cheers, Happy Smarting, Ian.
