There are good how-tos on both reference sites but here is how to get your lube of choice to penetrate and wet the whole length of the internals of the control cable.
There is very little clearance between the inner control cable and outer sheath. Most grease or oil applied will only be on the outer surface and all over your hands and very little will enter the internals.
Use vacuum:
Pull off rubber seal at handle end of control cable and immerse outer sheath of handle end in the lubricant. Suck on other end until it literally sucks. Of course, handle end of control cable has to be unclipped from door handle to do this.
Lubricants:
Mineral oils or greases will make rubber seal grommet swell leading to water ingress. I therefore use silicon based oils or grease. Also less chance of causing the plastic cover on cable to swell when using silicon based lubricants.
Use vacuum:
Lubricants:
