Hi, I am a Newbie to this site, having just bought a low mileage 2003 Pulse Coupe for my eldest daughter. The car only has 39000 miles on the clock and runs great but there appears to be a problem with the steering.
Unusually (or so I`m told) this car does have the electric power steering fitted, of this I am certain as I can see the electric motor attached to the steering rack and it has the control module next to the battery.
When stationary, or at very low parking speeds, the power steering works well and the wheel can be turned almost with one finger, but as soon as the speed goes above about walking pace the power steering seems to switch off and the steering becomes very heavy with no self centering at all. So heavy in fact that on the 60 mile drive home it made my arms ache.
I have read that bottom ball joints can seize, so jacked up the car and disconnected the steering arms, and both bottom joints are free, as are the track rod ends.
I also read that the universal joints in the column can seize, so checked these too and both are OK.
The car had a new battery fitted recently during which the radio code was lost, can the same thing happen to the power steering control module?.
Has anyone else encountered a similar problem and know of a cure?.
Will I have to replace the steering module, and does it need to be re-coded by a smart dealer?
Thanks in advance,
Ralph
Thanks in advance,
Ralph
