Hi my smart 450 cdi 2001 has packed in the engine just cut out, it finally started then cut out twice on the way home only about half a mile from my house it will not start unless i give it a sniff of easy start then it will run on its own without the spray any ideas, it had a crank sensor last year, do they have a cam sensor? cheers
450 fortwo cdi PROBLEM
I'd check the fuel pumps. A 2001 CDI I used to own had a fuel pump failure similar to how you are describing this.
- 1 like
Yes, Banchory Aberdeenshire, perhaps too far north and near nowhere?
Way forward in my opinion is:
1) Connect to diagnostics and read rail pressure when cranking engine.
2) Carry out compression readings.
Both require special equipment.
Did you fit original Smart/ Mercedes engine speed/ crank sensor?
Does engine smoke a bit when running? Perhaps try Silver Hook diesel injector cleaner available from Toolstation for £3.15 per bottle, enough for two treatments?
Does your high pressure fuel pump leak? Common problem with this Bosch CP1 pump.
crank sensor was from eurocarparts £45 im sure it was the same make, no fuel pump leaks and there is a bit of black smoke but always has been, what ya thinking possible valve issue if not pump I do have a compression set via glowplug which ive just changed should of done it then oops, i tried posting on your other replys but keeps saying text fault or something
Have you tried a battery disconnect/cold boot ?
Could be the rail pressure sensor.
Could also take glow plugs out to confirm injectors are injecting, you should see atomised fuel come out on cranking.Last edited by 10:45PM; 01-07-16, 07:45 AM.
Engine wll start with rail pressure sensor disconnected so easy to check if that sensor is the problem.
A real pity Delphi cannot display rail pressure for this 2001 Smart Cdi. Engine needs about 250 bar rail pressure to start. Perhaps you can try disconnecting connector to third pumping element on high pressure pump. Doing this may result in a fault code beng set but the main purpose is to allow all three pumping elements to pump. Pump element is enabled when solenoid is not energised. Solenoid simply operates a pin that keeps inlet valve in open position when solenoid is energised. The purpose of the cut off solenoid is solely to allow the pump to operate only two pumping elements, resulting in less engine power being absorbed at low engine loads.
More info: http://www.smartz.co.uk/showthread.p...Cdi-2002/page2
I suspect low compression. Low compresson wll make it harder for engine to synchronise on number one cylinder. Usually no fault codes. Similar to crank sensor failing.
How to measure compression on these engines: http://www.smartz.co.uk/showthread.p...re-compression
