​Brake seals
  • ​Brake seals
    I recently bought a back hub with all the accessories.
    Brake-ok linings, compensation mechanism - ok, bearing-ok, receiver cylinder.
    The cylinder failure is like a bleed on a piston => a sealing gasket.
    The piston is chrome-plated and smooth, but the seal is scratched.
    With a piece of soft material (eg wood or natural skin - from pig / cow), the cylinder is rectified and the gaskets are replaced.
    Here's the problem! Separate gaskets are not or have not been found.
    Which machines are using the same size?
    I gave up searching for suitable lip seals. Sourced complete Bosch wheel cylinders for less than typical seal kit cost.
      Bosch cylinder is around 35 pounds and seal are 3.5 pounds.
      Citroen Berlingo seals have 22.2mm OD but 16mm ID , Smart ID = 14mm.
