Hi there. Does anyone know if a handbrake from an ordinary Fortwo 450 will fit on a Brabus Fortwo 450? As far as I can see from photo's they are the same. Thank you.
Brabus handbrake.
Greetings, what part of the hand brake? The major part that's above the floor - that handle assembly that's bolted to the floor by two bolts? If so, I do, from a 450 model - slight problem, if you're in Blighty, I'm 13,000 miles away. But you never know, strange things do happen> Cheers, Ian.
