Central locking!!
  • Central locking!!
    I have a problem with the central locking, The buttons on the key fob work, but it won't lock nor unlock the doors or the rear tail gate, However the fuel flap does lock and unlock.
    ​When I press to unlock the indicator lights flash once, but when I press the lock button they don't. I can hear the relay working inside the zee unit when I lock and unlock, but no power goes to neither doors or tail gate from the connector to the zee unit, only power to fuel flap solenoid. I've tested each door switch by pressing lock and it unlocks immediately. Any idea's to what the problem maybe will be appreciated. Many Thanks, Kieron.
    Check the fuses.
    Did you prepare winter, especially lubrication actuators?
      Is your car damp inside?
