Hi All
Picking up a 53 plate Smart City Coupe Pulse (Smart Tip) on Sat. Already done a test drive etc and all is in order however I have a question re the Soft Tip gearbox fitted. I get that you have to manually change up sequential style however does the gear automatically change down for you ? I honestly cant remember if it did on my test drive. As an example if I am going along at say 50mph in 5th gear and I come to some lights if I just brake to a stop will it stop the car from stalling and down shift 4,3,2...
It would be good if it did but not a deal breaker if it didn't just have to remember as its not something I am used to (I have had either manual or full auto previously)
Also the dealership has given a copy of the MOT and it passed with 2 advisories - 'front left tyre under 3mm' of tread and 'slight corrosion on sub frame' , I don't really mind about the tyre as I was aware of that anyway and tyres for these cars are pretty cheap even for decent brands, should I be worried about the corrosion ? The fact it passed its MOT suggests its clearly not bad enough to be dangerous ? Note I am only paying £1400 for the car so I can't expect it to be mint especially after 15 years. It has verified service history and 53'000 miles on the clock (verified). HPI clear etc.
FYI - This car is going to be used very sparingly maybe 1000 miles a year , Essentially its for me to be used on the 3-4 days a month when I have to drive to my work's head office for meetings - Its a total return distance of about 12 miles (the rest of the time I cycle to work in normal clothes but for the meetings I have to be suited and booted).
Ta.
Ta.
