Sump Advice 450
    What sealant do you use on the sump, Tolsen?
      57 Varieties, at a guess
        No more untasty Heinz for me anymore only Lidl soups are being enjoyed. Nur das Beste oder Nichts as the Germans say.
          Here are some more details about the ECD oil pans.
          Drain hole is 20 mm lower than left and forward part of sump bottom. Oil therefore drains towards drain hole.
          Threaded boss is castelated and inverted allowing oil to drain through castelated slots at bottom of pan.
          This is the best oil pan you can source for your Smart 450 or Roadster 452. Particulary cheap currently only £18.35 with tracked delivery from Germany. See post 10 for Ebay link.
