Hazard lights flashing continuously
  • Hazard lights flashing continuously
    Hi I wonder of anyone can help me with a problem on a 2002 smart 0.6 (ZEE model)
    the car starts and drives fine, but as soon as you stop the engine the hazard lights are starting to flash continuously until you disconnect the battery
    to start it again, you have to connect again the battery(no hazard lights now) and unlock the car (at that time the flashing hazard lights start and they continue until you turn the ignition and start the engine)
    once started there are no Error codes and the car works as normal (all the electric work, apart from unlocking the boot -- it only makes a rely sound from ZEE module when you press to open the boot)
    when the hazard lights are flashing there is no indicator on a dash and they flash faster than normal hazard lights
    not sure what is wrong and not even sure where to start to look
    Use MB Star .
      I did not have a mb star, I swapped the entire ECU kit and hte problem is resolved
      I wonder if anyone know if the old faulty ECU kit can be repaired
