Intake Air Temperature sensor wiring
  • Intake Air Temperature sensor wiring
    Does anyone know which pins on the ecu connector goto the iat sensor on the smart fortwo 450?
    The Evilution site says 53 and 17 but theres nothing in number 53 and number 17 is a different colour wire to whats at the iat sensor
    What kind of car is it? CDI, petrol, Brabus or nonBrabus? In fact, everyone needs to know what the car is all about ...
    The IAT sensor is connected to an ECU (Smart450 has EDG for diesel and MEG for petrol) through a pin connector with pin numbers - MB Star shows the connector and the way the pins are numbered.
      It is a petrol non brabus 700cc
        This is the site I used
        https://www.evilution.co.uk/wiring%2...cu_pin_out.htm
          MEG.
          The connector leaves a color, the sensor gets the same color of thread (on the original). Check with a buzzer wires 17 and 53.
          Check the IAT with ohmmeter, http://smartmaniacs.co.uk/forum/the-...786-iat-sensor .
            Are these the correct points of the ecu harness that I have arrowed?
              Yes, this is also indicated on the www.evilution.
