Hi guys,
Looking for some advice on what is the best way to change both of these out. I have a 450 Brabus with air con and normal sized hands so its proving impossible for me to get at the end of the cranks case breather pipe (mine is actually split near the throttle body) and no hope in hell of getting to the top bolts for the front engine mount.
I was thinking if I removed the intake plenum would this allow me to get at both the top bolts for the front engine mount and the breather pipe and if I also remove the oil sump could I then get the front engine mount out (so I can replace it)?
