Test
Clutch biting point
Ref your visitor message.
This forum is on its last leg so I suggest you either go to Smartz, thesmartclub or clubsmartcar.
Your problem appears similar to what mine had in 2007. Clutch releases with a bang causing the wee smart to jump forward and engine often stopping.
Cause on mine was chafed cables to clutch actuator. Can also be caused by stiff clutch actuator.
