QUESTION; does the fuel tank separate from the filler tubes easily, I have limited room and I am trying to fix a hole in the bottom of the tank......i can see there is a reinforced joint at the bottom of the filler tube, and I just wondered if they come apart easily, or not....Thanks in advance
does the fuel tank separate from the filler tubes easily??
https://www.evilution.co.uk/Engine/4...tank_drain.htm
read that, is this what you are referring to, if so, bookmark the site.
It is likely I won't have access here for a while
