Hello all and thank you in advance.
Used 2003 pure 700cc semi auto. 168250 km on the clock
Problem 1: Electrics. When the left turn signal is on, the rear fog light turn on but only when the headlights are on. This is also tied to stereo ilumination which turns on and of when the left turn signal is on (but not when the headlights are on) . This also affects stereo sound as when headlights are on, sound is staticky and almost goes to zero.
Problem 2. There is no horn, I have been told there is a ribbon cable missing? can you advise?
Problem 3. Perhaps the most troubling, Shop which fixed oil leak from engine (kudos to them) mentioned that I need new gearbox, clutch etc. The car drives fine, the clutch doesn't slip, and it doesn't seem to be missing a gear or not being able to stay in any gear. There is as "pebble in a tin can" sound coming from behind, especially at 2nd and 3rd gear, which goes when shifting into 4th, 5th and 6th, but I don't know if that is relevant or not.
Any advice is greatly appreciated.
