Smart fuse box diagram and info
GuestTags: None
Re: Smart fuse box diagram and info
Well it is over 6 years old! try http://www.evilution.co.uk/293 if you haven't found it already or this http://www.evilution.co.uk/539
Originally posted by madDan View PostWiper Relay is external on Roady
Also on a 42 450 Mk2 -2000, the wiper relay is external, despite whats shown here:
http://www.evilution.co.uk/545
Relay "K" on my car is the heater blower relay, and the front interval wiper relay clicks somewhere else, further inside the facia panel.Last edited by ethanol-smart; 31-03-11, 11:36 AM.
Difference between 450 mk7 and Roadster relays are here:
Roadie:
http://www.fq101.co.uk/how-to-guides...onfig-452.html
fortwo 450:
http://www.fq101.co.uk/how-to-guides...onfig-450.html
There is a mismash of relays on the mk1-6s. All of them have engine relays located in the underseat fuse box but relays for other bits are either in fuse box eith the ZEE or dotted around the dash.
For example, the early fortwos which don't have a boot release solenoid have a different configuration to the others. There are later models (mk5/6 I think) which drop the dipped headlights when the ignition is turned off (but keep the side lights on) even with the stalk switched to dipped beam. These cars use a separate healight relay located within the dash.
