Hey everyone I need some advice I have just had the two rear tyres changed on my smart car and is causing the car to now slide out when I am cornering at any speed and I am not braking either smart technicians are puzzled they said at first it was the tyres I have had put on I had toyo tr1s put on so they tried changing them and still have the same problem the steering in a straight line is very light and I am always having to compensate more than before can anyone help me with this has anybody ever had this problem ???🤔🤔
Smart Fortwo kicking out front end
Mine (a 450 - yours?) understeered vehemently with smaller section front tyres than rears. Improved with 175s on the front and better still with 195/50-15s allround.
Hard to tell what is going on with yours though IMO you are overtyred at the rear and undertyred at the front. Might be worth checking the rear antiroll bar (assuming you have a 450) is as it should be.
Greetings, other suspects, wheel alignment - hit a curb or pothole recently? Tyre pressure? Wheel bearings / suspension play? Brake pads? The ABS light is illuminating because the ABS system has been activated, IE it thinks one or more wheels are not turning as much as the others, which could be caused by, tyre pressure, tyre diameter, or a brake pad or shoe making contact with the disc or drum. Have a look at the hand brake cables, they may have been crushed or squashed. Get all four wheels off the ground, release the hand brake and see if the rear wheels turn freely. See if the front wheels turn freely as well. If they 'bind', that's possibly your problem.
Cheers, Ian.
Hi they have tried re setting the ECU and it still was kicking out on the front end they are now saying it could be the front tyres I don't think by putting new tyres on the front is going to fix the problem could it be a faulty ABS sensor possibly what do you think Thrumbleux ? Ps thank you for all your input much appreciated 👍😃
Originally posted by alanb8222 View Postcausing the car to now slide out when I am cornering at any speed 0;
