451 CDI 2010 fuel gauge stopped working....
  • 451 CDI 2010 fuel gauge stopped working....
    As title, just seems to have stopped showing any bars on the fuel gauge.
    have disconnected battery over night and will see if that makes any difference.
    If no change, what do i do next?
    I also have the ESP ABS light coming on intermittently, the fault was traced to right rear ABS sensor which was replaced with genuine. the problem persisted so the reluctor ring was replaced, the problem still exists and can be off for many days then will just come back. I did buy 2 reluctor rings from smart mods so I may change the left side just in case.
    other than that the car is fine.
    ok battery reconnected and so far it seems to have solved the problem, but i cant believe its that simple.
      fingers crossed then
