Hello,
Just wanted to check if someone had any ideas on possible solutions to starting problems with the 451 MHD.
Whether hot or cold my smart has issues starting, sometimes I have to turn the key 2-3 times before it finally stumbles and fires up.
I get the feeling that the starter-alternator turns more slowly than usual and it has gotten worse over the last few weeks.
There are no issues with the alternator charging voltage.
Thanks in advance!
/Alex
- I have replaced the battery with a new AGM unit.
- No error codes presented.
- Checked and cleaned battery and starter connections / cables.
- The Poly V-belt is new and not slipping.
Thanks in advance!
/Alex
