Got a roadster in that got stuck on the road and would not start(3 Bars), i got the selector lever cleaned (broken o-ring on circuit board), 4 fault codes before start working - P2034, P202B, P202F, P2022. After repairing selector lever no fault codes present, turns on but when crank starter motor only kick in and release (similar to loose wire) checked everything try to hot wire starter solenoid still the same doesn't turn engine, do i miss something. motor did crank and fire after i got it into "N" but not selecting gears.
Roadster engine not turning
