What sort of switch is the ESP disable ?
  • What sort of switch is the ESP disable ?
    Hello,
    Can one of your Roadster owners do me a favour and tell me what sort of switch the ESP disable button is ? Is it a press and it stay pressed sort ? (where if you press it and turn the engine off the ESP is still disabled when you turn back on again? ) Or a momentary type switch which just toggles on/off and does not remember when the car is turned off then on ?
    I'm looking to find a suitable button to fit to my 450 :-)
    Thanks!
    Mark
    It is the second alternative!
    If You turn the ESP off and then turn the engine of and back on the ESP will not stay off.
    Jörgen
      It's a momentary switch.
        Thank you very much! On to the next part :-)
          IIRC the momentary switch generates a pulse to the SAM which iniates the disabling of the ESP.
          MB are anally retentive when it comes to safety and I presume thats why the software would automatically
          're-engage' the ESP when you switch off the engine.
            The switch just grounds a transistor in the SAM causing it to switch.
