Wouldn't start last night after a three mile trip down the road. Dashboard EMS light off, along with all others, brake lights come on, fuel pump sounds as if priming the system ok. Clutch actuator activates, gearbox knows which gear it's in (or isn't), yet the engine won't turn over. Not even an attempt. All the relays in the SAM sound as though they click as per normal.
Run out of ideas for what else could be stopping the sequence. Will try disconnecting battery this afternoon for a full reboot, but all suggestions gratefully received. Nearest smart dealer is 100 miles and 2.5 hours away...
