Newbie with some questions...
  • Newbie with some questions...
    Hi all,
    Acquired an 04 Roadster last week - couldn't resist it ! It's in need of some work & general TLC, so felt I could help get it back to it's former glory.
    Electrics all function OK, with the exception of Central Locking.
    If I use the Key Fob to lock the car, the doors locks cycle (lock/unlock)
    However, if I sit in the car and use the dashboard lock button, the doors lock
    I've joined Evilution and discovered the door locks have integrated sensors to give locked/unlocked signal (to SAM I guess ?), so I must assume both door locks are OK, as they lock when using the dash button ?
    I'm now thinking maybe it's an issue with the 433Mhz system (Key receiver module ?)
    I'm certain others here must have had exactly the same issue - any pointers as to the likely cause ?
    Doors won't lock if one door is not latched. Perhaps there is some logic built into the internal lock button making most doors luck for security reasons. This is something I have not tested so could be wrong.
      Just tried it with my rear hatch open on my 451 and the interior doesn't even respond although the remote will still attempt a lock/unlock cycle.
      Suggest you check the fuel filler door lock is operating correctly and all other locks , although it may not prove conclusively the various switches within them are working fully when they're supposed to , but I'd still suspect a dodgy lock rather than the receiver module 1st.
        It's a single earth wire that fails internally, it's a new common issue on the Roadster. I had this on a Roadster I had back in 2010 and it took a solid 24 hours of continuity checking to work it out (along with a return power feed wire from the ECU to SAM that was causing a CAN bus issue). As you were kind enough to join my site, email me directly and I'll talk you through the fix.
          That is what I call good service.
            Hi Tolsen & 10:45,
            Many thanks for your input - I've now contacted Evilution to take him up on his offer of help - hopefully will have this locking issue fixed shortly.
            Car seems to be running fine & has scrubbed up nicely... but 15" Spinline wheels are badly corroded
            I have a few other issues that I hope you can help me with over the coming months - I will post a new topic now on the second problem I've noticed....
            Regards
              FIXED
              BIG thanks to Evilution for the fix !
              Doubt if I would have ever found the issue myself .....
