New gearbox?
  • New gearbox?
    Hi,
    On the way to work this morning I got the 3 lines on the dash, when I try to put it in to gear I just get a banging sound, any suggestions what it could be?
    Thanks,
    Alex
    Clutch actuator and/or its and associated transmission wiring.
    The gearbox will be fine - just an external fault.
      Hi,
      I had the actuator adjusted 4 weeks ago, could be a new clutch ?
      If it needs a new clutch, would a Brabus clutch improve performance?
      Alex
        Originally posted by hellblazeruk View Post
        Hi,
        Could be but begin with the simplest, cheapest to fix first. From past experience, when the clutch actuator fails to perform, there is a clanging sound as gear selection is attempted.
        Alex
        It's only a coupling.
          thanks for the help, just need to find someone in Nottinghamshire area to take a look.
          Alex
            It's worth having a quick look under the car from behind just in case it has fallen off - as mine did. If so, it will be hanging there by its wires. (The mounting lugs corrode and break. If your adjustment 4 weeks back involved disturbing the bolts.....)
              fallen off
              I will check
