Hi, I'm a brand new roadster owner just feeling my way around the car at the moment. I bought my 04 roadster as a non runner with "possible immobiliser" issue, I've spent the last week drying her out and sealing the scupper plate (?) Now I need to buy a rain hood (?) To stop the ingress from the roof, unless there's a better fix.
My starting issue, now that I've fitted a new battery and tried to start is as follows;
Unlock, single indicator flash
Switch key to first position, 3 internal beeps and a click from the front somewhere
Turn key and a click from the right hand side of the dashboard, no turnover
Only the right display cluster (revs) is lighting up (airbag sign!), the left is dark
Both keys may have new battery each
When key is turned to the first position and the central locking button is pressed it flashes rapidly
Sorry if this has been answered before, none of the other starting/key/immobiliser threads I've found have the same symptoms (they usually all have 9 indicator flashes)
