Hello,
Rig build is coming along nicely... However... I'm coming across a few issues with the Channel switching. Using the external jacks on the back and plugging straight into the NO/OUT on each loop required. Facing issues with switching between Channel 1 > 4 - it seems it keeps the channels on - so running Channel 2 & 3 at the same time? Does that make sense? Is there a setting on the GCP I need to change?
Any help will be apprecited.
I didn't find the right solution from the Internet.
References:
Web Animation Studio
Thank you.
References:
Thank you.
