Greetings All, slight problem, how does one test an alternator when it's not attached to the engine. A Smart alternator that is. It was tested by an auto electrician and declared dead! Funny, as it came from a car that had another problem - a dropped valve and not a faulty alternator. So, is there any 'tricks' to being able to test a Smart alternator on the bench? I'd suspect that clamping it in a vice, applying 12 dc across the 'HP' terminal to ground and then rotating the pulley clockwise, should produce volts at the discharge stud, from between 13 to 16 volts. Or, am I smarting up the wrong tree?? Any suggestions?? Or do I have a dead alternator? Cheers, Ian.
Off the car Alternator test?
