I have searched on most of the forums and found virtually no posts relating to rear wiper motor failure, so before I go and order a replacement, I wondered if anyone else on a 450 has had one go, or if there's another issue at play?
Basically, on ours, it moves a bit and stops - if I give it a shove it carries on moving - but needs a helping hand to do a full sweep.
Coincidentally about a month ago I fitted a replacement wiper arm & blade (for a Nissan Micra) but even if I remove the arm completely, the motor struggles to make a full sweep with nothing attached.
So naturally I'm assuming the motor is weak, but I would have surely I'm not the first to suffer this, and I can't find anyone else having had it fail - so before I shell out for a replacement, any other ideas?
