I recently bought a Smart, 0.6 / 40kW but with problems.
Not engage in speed ,clutch kit was replaced with a new 1 year ago.
Taking down I found the cause - namely faulty clutch pressure plate tabs that hold the solar spring are broken - all 3.
https://plus.google.com/photos/11282...19251321894610
https://plus.google.com/photos/11282...18831510755506
After market ,made in China or something .
I will try to recondition it but I have no blades ...
During disassembly I found:
- Assisted braking valve broken and glued with cyanoacrylate;
- 1 hose Admin main air hose (air filter turbo) split;
- one from the hose connecting pipes are broken 80%;
- another connecting pipes repaired with epoxy resin.
- 1 reluctor split.
- 1 reluctor split.
