The part that connects the rod from the diaphragm actuator part (the thing with numerous small bore flexible hoses attached) to the turbo waste gate arm has rotted through and broken on my car and I need a replacement. Main dealer couldn't find the part - not helped by my lack of correct terminology.
Does anyone know the name of the part, whether it is available from main dealer, available from anyone at all, or a repair that can be done - preferably without having to remove the entire 'actuator' thing? TIA.
The bit I'm looking for slips over a pin on the waste gate arm and is secured by the circlip (that normally corrodes away) and is threaded internally through its length to accept the rod from the 'actuator' thing - if that description helps identify it.
