What device did you find this code (p205c)?
This code corresponds to a fault on B50 (fuel temperature sensor), B50 is located on the fuel pump. https://www.engine-codes.com/p205c.html
A / C pipes can damage the sensor connection, do you have A / C on the car?
Made a call to smart center, they said its outside temperature sensor. its interesting, because it come up vhen my engine cuts off while i was driving.
Replace the sensor, when viewed from front of car, lower right hand side scoop hole.
Get the outside temperature sensor activated for your car if it isn't already.
Get the outside temperature sensor deactivated for your car if it is already activated.
No idea if your Delphi diagnostics can do that activation - MBSTAR and WINSTAR can.
Reading outside temp isn't a feature of my Pure. But after some work by main dealer, the fuel countdown is different from before and it shows outside temps. Outside where I know not as the figures are in deg F and there' invariably three of them. Some distant planet closer to the sun than us?
Does that temp sensor though provide info to MEG for controlling fuelling?
thats not a outside remperature sensor like i have told., today i disconect outside temperature sensor and in fault code its says (ambient temperature sensor) so, its mean then what is that ATMOSPHERIC PRESHURE SENSOR.?????
The probability of correct diagnosis with Delphi is 50%. Intermittent marking of the fault means that it can be deleted. Did you try to delete the error memory?
Please diagnose Smart Car with MB Star / Winstar .Only.
