Sorry another post by me...
Further to my last posts and given my nervous nature I am still concerned about the dreaded blown engine - I want to keep my Smart 450 Pulse going as long as poss ideally if I can get it up to 65k then that should do me for 2 years by which point I will have covered the cost of commuting compared to using the train, if it carries on past this point happy days!
We also have a 64 plate Aygo and this gets used for everything else so the Smart is literally used 20 miles a day 5 days a week - To work and back. I have tried to convince the missus to share the Aygo so she takes the Smart some days but she is having none of it - If it ain't full auto with reversing camera and power steering then she ain't interested (None of which is on my Pulse).
The Smart just ticked over to 53'000 miles. I have been told to keep on top of the services and use decent oil (5w/30 fully synth) , Car was recently serviced with new oil filter and decent oil and I swapped out the standard air filter to a upgraded foam filter (so I can just wash it when needed).
I will be having the discs and pads swapped this weekend and I am going to swap out the 6 plugs at the same time (not done on last service) so I am trying to keep on top of the stuff I can do myself.
I have been driving very gently (I don't drive quickly anyway) and I have been letting the car warm up to at least 2 blobs before using the loud pedal and even then i have been changing gear at 3500 rpm or less , I have let the car idle in N for a minute at the end of a journey to allow it to cool and I only drive if the journey will be long enough to get the engine warm - No 5 min trips to the shop etc. Finally I have been checking the oil after its warmed up every week and making sure it sits bang in the middle of the dip stick (when warm)
So in terms of keeping on top of it I think I am covered but I have heard conflicting opinions on how best to keep the engine running sweet.
Can someone give me a yay or nay to the below , this is the advice I have been given elsewhere :
1. Once warmed up use high revs every now and then to clear out carbon deposits ?
2. Always change into N at lights etc no in gear with the foot brake on ?
3. Avoid using high gears on hills as this will stress the engine, drop down to a lower gear even if this pushes the revs up a bit ? i.e no 1800rpm in 5th instead use 2500rpm in 4th.
Thanks in advance.
Thanks in advance.
