Battery Disconnection.
  • Battery Disconnection.
    Should I disconnect the battery both leads [ or just the negative lead ] before I remove the transmission control unit on my Fortwo mhd 2009 1 litre. thanks for your time.
    The safe way to disconnect battery on a negative goround vehicle is always disconnecting negative terminal first.
    The reason is, if you first disconnect positive terminal there is always a risk of your spanner touching chassis whilst loosening positive terminal.
    By first disconnecting the negative it does not matter if you then accidentally touch chassis with your tool.
      Many thanks for reply,
