Hello my Smart Roadster started knocking ONLY at 6th speed specially with full throttle and more specific on rising road
I gone to smart and the system detects problem with knocking sensor. I change it with NEW(bosch).Also timing belt changed.
The scanning tool continues to showing the same error.
I run a dyno test and checked the map and everything showing perfect.
I run a diagnostic test for the cylinders on road and I verified that the knocking problem is on 3rd cylinder and only in 6th speed.
I changed the fuel filter and I am running only 100 octane fuel. I used also a FI cleaner oil (mixed with fuel).
The problem insists. Any ideas??? Thanks.
