I have evidence that Suplex has lost track and incorrectly marked at least one lot of rear coil springs for the Smart Roadster.
Here is the story:
I ordered a pair of Suplex 19265 coil springs. These are standard rear springs for the Roadster.
Suplex 19265, Length = 239 mm, Wiresize = 10.25 mm, Coil Outer Diameter = 99 mm.
I only received one spring from Suplex, the second spring on a back order. Surprisingly, the received spring was both shorter and have thicker wire size than that specified in spite of being identified by a sticker stating Suplex 19265.
So I measure the dimensions of the spring received and conclude Suplex UK Ltd has sent me this one which is intended for the Roadster Brabus:
Suplex 19277, Length = 205mm, Wiresize = 10.50 mm, Coil Outer Diameter = 103 mm.
Wonder if anyone else have had same problem when ordering Suplex springs?
My supplier has confirmed I can keep the non conforming spring. Anyone needing a very cheap rear coil spring for a Roadster Brabus, please shout. Fee equivalent to two pints of good ale (Aberdeenshire prices) plus postage at Royal Mail prices (GBP 3.80 for 2nd class).
Here is the story:
