Heater lights
  • Heater lights
    Hi all, sounds a bit daft but does the heater slider and controls light up at night when you put ya lights on, it's been so long since I've had them on I can't remember. Everything else is lit up other than the heat/cool and the directions.. Sent from my HTC One_M8 using Tapatalk
    Yes it should, bulb is under the triangle where hazard switch is
      Fantastic thank you ... � Sent from my HTC One_M8 using Tapatalk
