Just received an aftermarket thermostat bought on ebay. Price just below £20 with free delivery.
Its internal check valve is fitted wrong way around meaning engine will constantly leak warm coolant to radiator and therefore take forever to get up to operating temperature.
Water runs out as quickly as it runs in. No good for a warm and cosy cabin on cold wintry mornings.
This thermostat has no number or name. Can be distinguished from the original Wahler by the clip that hold temperature sensor in position. Clip on this one looks far eastern in origin, is made from thin 0.7 mm diameter round zinc plated wire and does not clip on securely. Clip on the Wahler is made from heavy duty square zinc plated wire.
Another thermostat to avoid is the Gates TH40390G1 for the diesel 450/451. The gates is just as bad as this one.
