Oil Filter
  • Oil Filter
    Hello.
    Does anyone have the dimensions for the 450 Smart 700cc engine oil filter housing, including the stubby pipe the filter pushes on too.
    Cheers Oldgt
    Measuring a new filter, the hole is 15.3mm diameter (so obviously the stub is a touch larger, and the O ring (same as housing diameter) is circa 60mm - which should give ball park figures.
    I'll measure the depth (horizontal dimension when fitted to the car) of the housing later today. (The filter itself is 55.4mm tall with an OD of circa 52mm).
      The housing is around 50mm deep (horizontal dimension when fitted to the car) with 18mm of that being the hexagonal head.
