New posts technical issue
  • #31
    Re: New posts technical issue
    1111000011110011111111001111111100001111111100000
    1111100011110011111111001111000111001111001111000
    1111110011110011110000001111001111001111000111100
    1111111011110011111111001111111100001111000111100
    1111011111110011111111001111011110001111000111100
    1111001111110011110000001111001111001111000111100
    1111000111110011111111001111001111001111001111000
    1111000011110011111111001111001111001111111100000
    • #32
      can't read yours harry but i've a feeling we've both done a similar thing. :eek:
      • #33
        01101010011101010111001101110100001000000110001101 10100001100101011000110110101101100101011001000010 00000110000101101110011001000010000001101101011010 01011011100110010100100000011010010111001100100000 01100001001000000110011101110010011000010111000001 10100001101001011000110110000101101100001000000110 01010111000101110101011010010111011001100001011011 00011001010110111001110100
        • #34
          Originally posted by gavinc View Post
          Brilliant.
          010010010010000001101100011010010110101101100101
          001000000111010001111001011100000110100101101110
          011001110010000001101001011011100010000001100010
          011010010110111001100001011100100111100100101110
          001000000100100100100000011001000110111101101110
          001001110111010000100000011101000110100001101001
          011011100110101100100000010010010010000001110111
          011010010110110001101100001000000111000001101111
          011100110111010000100000011010010110111000100000
          011101000110010101111000011101000010110000100000
          011101000110100001101001011100110010000001101001
          011100110010000001100110011000010111001000100000
          011101000110111101101111001000000110110101110101
          011000110110100000100000011001100111010101101110
          00101110
          • #35
            4f 68 20 79 6f 75 20 67 75 79 73 20 61 72 65 20 73 6f 20 66 75 6e 6e 79 21
            • #36
              123 157 155 145 040 163 141 171 040 164 150 141 164 040 150 151 163 040 142 162 145 141 164 150 040 163 155 145 154 154 163 040 157 146 040 155 141 147 156 145 163 151 165 155 054 040 141 156 144 040 164 150 141 164 040 150 145 047 163 040 163 143 141 162 145 144 040 157 146 040 142 145 154 154 163 056 056 056 040 141 154 154 040 167 145 040 153 156 157 167 040 151 163 054 040 150 145 047 163 040 143 141 154 154 145 144 040 164 150 145 040 123 164 151 147 056
              (It's in base 8 if that helps... )
              • #37
                123 157 040 154 145 164 040 155 145 040 147 145 164 040 164 150 151 163 040 163 164 162 141 151 147 150 164 056 040 131 157 165 040 167 141 156 156 141 040 146 154 171 040 157 156 040 141 040 155 141 147 151 143 040 143 141 162 160 145 164 040 164 157 040 163 145 145 040 164 150 145 040 153 151 156 147 040 157 146 040 164 150 145 040 120 157 164 141 164 157 040 120 145 157 160 154 145 040 141 156 144 040 160 154 145 141 144 040 167 151 164 150 040 150 151 155 040 146 157 162 040 171 157 165 162 040 146 162 145 145 144 157 155 054 040 141 156 144 040 171 157 165 047 162 145 040 164 145 154 154 151 156 147 040 155 145 040 171 157 165 047 162 145 040 141 154 154 040 143 157 155 160 154 145 164 145 154 171 040 163 141 156 145?
                • #38
                  quite right... boys from the dwarf.
                  • #39
                    WW91J2QgbmV2ZXIgZ2V0IGEgY2F0IHRvIGJlIGEgc2VydmFudC 4gWW91IGV2ZXIgc2VlIGEgY2F0
                    IHJldHVybiBhIHN0aWNrPyAiSGV5LCBtYW4hIFlvdSB0aHJldy B0aGUgc3RpY2ssIHlvdSBnbyBn
                    ZXQgaXQgeW91cnNlbGYhIEknbSBidXN5ISBJZiB5b3Ugd2FudG VkIHRoZSBzdGljayBzbyBiYWQs
                    IHdoeSdkIHlvdSB0aHJvdyBpdCBhd2F5IGluIHRoZSBmaXJzdC BwbGFjZT8i
                    • #40
                      quite right... :d boys from the dwarf.
                      01001111 01110010 00100000 01100001 01110011 00100000 01001011 01110010 01111001 01110100 01100101 01101110 00100000 01110111 01101111 01110101 01101100 01100100 00100000 01110011 01100001 01111001 00111010 00100000 01001111 01101000 00101100 00100000 01110011 01110000 01101001 01101110 00100000 01101101 01111001 00100000 01101110 01101001 01110000 01110000 01101100 01100101 00100000 01101110 01110101 01110100 01110011 00100000 01100001 01101110 01100100 00100000 01110011 01100101 01101110 01100100 00100000 01101101 01100101 00100000 01110100 01101111 00100000 01000001 01101100 01100001 01110011 01101011 01100001
                      • #41
                        We seeing how many different encoding schemes you can fit in a single thread?
                        • #42
                          we seeing how many different encoding schemes you can fit in a single thread? :d
                          • #43
                            outgeeked after we'd moved past hex.
                            • #44
                              • #45
                                No, it's fine. Stick with this one.
                                So far we've had binary, hex, octal, morse code, base64 and data matrix... lol
