Server maxed out??
  • Server maxed out??
    The site is basicly not working for me. Every post is followed by server busy errors and pages are taking a few mins to load if they do at all! Its not just be because every other site it loading instantly.
    Is there something wrong? :frown:
    :thanx:
    Re: Server maxed out??
    Seems to be fine this end
      Nothing wrong here!
      Fudge!
      fudge@fudgesmart.co.uk
      www.fudgesmart.co.uk
      www.sw-x.co.uk
        There is something which seems to be draining resources. it's effects appear to be random.
        I'll admit to knowing no more than that, but we do know there is an issue...
        Rich is on the case.
        (Rich, get on the case lol)
          Have you tried switching it off and on?
            ****ing IT muppets
              Originally posted by phildperv View Post
              ****ing IT muppets
              LMAO!
              @JamesMackB
                It's a bit odd why it should be a memory leak in a script as each php script is run, the memory it's used dies once the script has finished. It's more likely to be either a database connection that's being kept open, or the site is configured to use persistent connections to MySQL instead of dropping them after each script has run and it's maxing out the MySQL memory.
                If RichG would like some help tracking down the offending script, he can always ask for it...
                  I have the same problem.
                  I figured someone had put me on a go slow for been bad.
                  nice to know its not just me.
                    System is running fine from the admin control panel. Anyone experiencing problems can contact admin direct: here.
                    @JamesMackB
                      I dont know whats going off but from about 9 last night links are taking minutes to load and im getting random 404 errors and "the server is too busy, please try again later" errors. Posting this ill click send and it wont do anything for a minute then it will eather work or come up with a server busy error.
                        Are there any threads popping up on theroadster.net about 'the situation' yet ?
                          Go have a look
                            Arh! I have been through 2 mins of "server is too busy, please try later" errors to get to this page to load!
                              Originally posted by DaisyDuke View Post
                              Go have a look
                              Is is access denied now for you then?
                              @ Jc Denton: smartmaniacs loading is fine here ?
