whistle
  • whistle
    I was hearing a whistle each time I pressed the accelerator while I was driving home last night and I couldn't work out where it was from. That was until I turned the radio off and it stopped and realised it was coming from the speakers. A couple of day before when I was breaking it interfered with the radio signal. Does anyone have any ideas what is causing it?
    Re: whistle
    you're picking up electrical noise from either a poor/damaged aerial shield cable or via the power in.
    I'd check the cable 1st at both ends visually, check it's fully installed into the radio end and then with a meter.
      Re: whistle
      It is prob the radio wire as it never seems to hold properly. I prefer the old male, female slot in ones I had on my old radios.
        Re: whistle
        Do you mean behind the radio where it all connects?
          Re: whistle
          also check your earth near you battery in the passenger foot well !
            Re: whistle
            both really, check the plug is fully in at the rear and then you may need to get at the aerial base to check that too
              Re: whistle
              Hi,
              I also get a noise when I listen on A.M. (sport etc). If I have my foot on the brake when stationary there is a background whirring. I am pretty sure it is the hillstart assist since it doesn't happen while braking on the move and stops a split second after I take my foot off the brake.
              Pete
